The XE3-4TN is a software defined outdoor wireless access point with various antennas options. It contains a 4x4 and 2x2 radio set inside each WAP.
If possible, it would be amazing to convert the 2x2 radio into a ePMP or PMP 450 Subscriber Module with an additional license.
This would enable easy backhaul options for wide area wireless deployments above the range usable by cnWave.
In mobile applications, it could used with PMP 450 nomadic operations.
