Xirrus Warehouse Technology Integration - Scanners
Has anyone been able to successfully able to integrate Zebra TC8000 and Zebra TC8300 scanners with Xirrus APs.
I can not make it work reliably and am about to give up.
Hello Paul,
I am not sure, but you can try to find the ports or COM or serial port of Scanner. And try to priorities that protocol using Xirrus application control.
Arefin
