XV2-2 replacement
Hi All,
We are not able to purchase XV2-2 anymore, would XV2-2X be replacement with similar performance and price range?
Kind Regards,
Piotr
Hi Piotr,
XV2-2 aka XV2-2X is still available to be ordered. Can you elaborate on the difficulty in ordering it?
XV2-21X is another dual radio alternative. It doesn’t support as many connections as XV2-2 and has a Gig port while XV2-2 has a 2.5GE capable port. Chosing the appopriate AP depends on the applicaiton.
Hi Brian,
Thanks for your reply.
One of our supplier inform us that XV2-2 are no longer available… Is XV2-2X corresponds to the same model as XV2-2.
Kind Regards,
Piotr
Yes, the XV2-2 has the part number of XV2-2X.
