We are installing the wall mount XV2 -22H and we need to use ETH2 port due to installation restrictions on ETH1.
We are unable to get the tagged VLANS working & no clients get an IP on ETH2. The native VLAN works just fine and we have communication with the AP, tagged VLANS on the WLANS we have an issue.
If we use ETH1 then all works as should. We have proved the clients switches not to be at fault.
Is there anything we are missing in our config that we would need to enable when using the ETH2 port.
We have applied the same VLAN rules under APGROUP> NETWORK as we have in ETH1.
