XV2-2T with Force 300 backhaul into eth2
Looking for best practice or desired config setting up the accesspoint with a Force300 off eth2 for dedicated backhaul to the tower. Any docs or guides out there?
Hi, if using Eth2 port on the XV2-2T, ensure the Eth2 and Eth1 ports configured properly for access ports bv trunk ports, the correct VLAN as Native VLAN (untagged or tagged) and for Trunk ports, the correct allowed VLAN. Also, for this configuration you will not use port channel (aka 802.3ad LACP). Hope that helps.
