in my cambium force 200 i got 10 mbps ethernet status?
can you help me?
can you help me?
Assuming that you didn't damange the ethernet interface somehow by using a 48vdc PoE on it as inidicated in your previous posts... you can try the following:
- Use a Cambium 30vdc PoE
- Try using a different switch or PC to connect to the radio that is known to work properly at 100/1gbps with F200
- Try using a known working network patch cable that you've tested with other F200's at 100/1gbps
- Reset to factory defaults, and try again
- If all of this fails, contact Cambium support and hope that they allow you to RMA the radio
