Answer: The ePMP device may be configured for Manual Ethernet port speed configuration or Auto-negotiation.
AP
These configuration parameters may be found at Configuration > Network
Ethernet Port Configuration |
Manual: The LAN Ethernet port speed and duplex mode can be manually configured. Auto-Negotiate: The AP auto negotiates the LAN Ethernet port speed and duplex mode with the device connected to it. |
Port Speed |
With “Ethernet Port Configuration” the LAN Ethernet port speed can be forced to 1000 Mbps, 100 Mbps or 10 Mbps. |
Port Duplex Mode |
With “Ethernet Port Configuration” the LAN Ethernet port duplex mode can be forced into Full or Half. |
SM
Manual: The LAN Ethernet port speed and duplex mode can be manually configured. Auto-negotiate: The SM auto negotiates the LAN Ethernet port speed and duplex mode with the device connected to it. |
Port Speed |
With “Ethernet Port Configuration” set to Manual, the LAN Ethernet port speed can be forced to 1000 Mbps (only GPS Synchronized radio), 100 Mbps or 10 Mbps. |
Port Duplex Mode |
With “Ethernet Port Configuration” set to Manual, the LAN Ethernet port duplex mode can be forced to Full or Half. |
