To ensure your on-premises deployment stays secure and reliable, we recommend integrating these best practices into your installation. Please check back regularly as the threat landscape evolves.
Confidentiality
Make use of cnMaestro RBAC (Role-Based Access Control)
Not everyone in the team needs to be a Super Administrator– use the predefined roles in cnMaestro to mitigate risks from attackers as well as human error.
Segment networks
Keep device management interfaces on separate LANS and limit access to cnMaestro and authorized infrastructure management networks only.
Do not allow management access from the internet
Restrict the management interface to trusted networks only. While Cambium strives to deliver secure code, vulnerabilities can be found anywhere. Removing an attacker’s ability to attempt potential exploits adds another layer of defense. The cnMaestro appliance should be installed behind a dedicated security system if possible.
Separate management and device traffic
Devices can have a dedicated network that does not allow direct access, this helps prevent unauthorized access to devices, and ensures all changes are managed centrally.
Update TLS certificate
Update the HTTPS certificate on your on-premises instance with your own signed certificate. This will ensure management traffic is less susceptible to interception.
Encrypt disk
Encrypting the storage at the backend for your on-premises instance ensures an attacker that gains access to the storage for your virtualization system cannot extract network information and secrets.
Change passwords
Password changes are enforced after first use on most products, but you may want to update these yourself.
Use your existing IAM (Identity and Access Management) (X)
Connecting to your existing authentication source means no orphaned accounts lying around after people leave. cnMaestro supports TACACS+, RADIUS, LDAP, Active Directory, OpenID Connect (OIDC), and SAML.
Integrity
Back up regularly, automatically
Configure your cnMaestro instance to automatically back up on a schedule that suits your system. If you are regularly updating and changing config, set backup frequency to the maximum lost changes that you can tolerate, e.g., if you can recover from losing only today’s changes set a daily schedule. If you can recover using last week’s changes, set a weekly schedule. It is also useful to do a full disk backup, details depend on your virtualisation backend with details in the use user guide
Send logs to a centralized collector and monitor them
cnMaestro can output via syslog to a centralized server. Configuring this ensures integrity of logs and can be useful for investigations and auditing.
Upgrade software as security updates become available
Cambium Networks regularly publishes maintenance releases of cnMaestro, and it may also publish security updates when needed. Make sure these are installed as soon as possible to maintain security.
Availability
Set up HA (High Availability)
Configure an HA cluster so service is maintained during accidental outages.
Test backups
Regularly test restoration of backups and include cnMaestro as part of your incident response plan. It is recommended to restore backups to an isolated clone instance for restore tests.
Take a VM snapshot before upgrades. This will help recovery if anything goes wrong during the upgrade. Ensure that snapshots are cleaned up after verification of the upgrade, in some setups, running from a snapshot long-term may impact performance.
Validate hardware
As your network grows, your initial hardware specifications for cnMaestro may no longer be enough. Remember to review assigned hardware for your VM when adding devices or making network changes.
