since a few days I try to connect a Raspberry Pi with an RTL 8191SU chipset WLAN-Adapter to my WLAN with E400 accesspoints. The Pi runs a Linux system "Raspbian Jessie".
It seems to connect but then gets immediately disconncted.
A connection to a Zyxel Accesspoint with the same configuration works without problems. I upgraded the E400 to firmware version 3.4.3-r9, but the problem still remains. I've changed the channel width to 20 MHz and Multicast Data rate to "Highest supported", but no success.
Here is what I find in the log:
Aug 23 21:13:30: wifid : Client[00-87-24-93-FA-74] on ssid Abbey internal cache based vlan is 0 (apd.c:82) Aug 23 21:13:30: wifid : client [00-87-24-93-FA-74] on ssid Abbey vlan 1 state sync (type:1) sent, len[128] (cache.c:1253) Aug 23 21:13:30: scmd : Dropping message to autopilot master, registration not completed (connect.c:604) Aug 23 21:13:30: scmd : Event write failed (pid:494). error 2:No such file or directory (main.c:1070) Aug 23 21:13:30: scmd : Aug 23 21:13:30 WIFI-6-CLIENT-CONNECTED Client [00-87-24-93-FA-74] connected to wireless lan [Abbey] (main.c:1 Aug 23 21:13:30: wifid : client[00-87-24-93-FA-74] on vap_id[0] wlan_id[0] created in coplane (stats.c:217) Aug 23 21:13:30: wifid : client[00-87-24-93-FA-74] current ssid[0][Abbey] and it's cache ssid[Abbey] (cache.c:1838) Aug 23 21:13:30: wifid : client[00-87-24-93-FA-74] no hotspot session found (hotspot.c:821) Aug 23 21:13:30: wifid : Client[00-87-24-93-FA-74] on ssid Abbey internal cache based vlan is 0 (apd.c:82) Aug 23 21:13:30: wifid : Failed to get stats for client[00-87-24-93-FA-74] on wlan 1 (wifi_stats.c:36) Aug 23 21:13:30: wifid : IEEE80211_IOCTL_STA_STATS failed (stats.c:265) Aug 23 21:13:30: wifid : client [00-87-24-93-FA-74] on ssid Abbey vlan 1 state sync (type:1) sent, len[128] (cache.c:1253) Aug 23 21:13:30: wifid : client[00-87-24-93-FA-74] on vap_id[0] wlan_id[0] created in coplane (stats.c:217) Aug 23 21:13:30: wifid : client[00-87-24-93-FA-74] current ssid[0][Abbey] and it's cache ssid[Abbey] (cache.c:1838) Aug 23 21:13:30: wifid : client[00-87-24-93-FA-74] no hotspot session found (hotspot.c:821) Aug 23 21:13:30: scmd : Dropping message to autopilot master, registration not completed (connect.c:604) Aug 23 21:13:30: scmd : Event write failed (pid:494). error 2:No such file or directory (main.c:1070) Aug 23 21:13:30: scmd : Aug 23 21:13:30 WIFI-6-CLIENT-DISCONNECTED Client [00-87-24-93-FA-74] disconnected from WLAN [Abbey], after [0 Aug 23 21:13:30: wifid : client[00-87-24-93-FA-74] on vap_id[0] wlan_id[0] deleted in coplane (stats.c:217) Aug 23 21:13:36: scmd : State timer callback. autopilot state = 0 (connect.c:659)
Thanks for the reply! There is no reason for the disconnect shown in the GUI-page. It simply says "Client [00-87-24-93-FA-74] disconnected from WLAN [Abbey], after [0] secs and used txbytes [0] rxbytes [0]".
This is a wpa2-psk secured WLAN with SSID "Abbey".
hi please share ap techdump to channareddy.ireddy@cambiumnetworks.com. we will look into this one. in the mean time can we downgrade ap to 3.3-r16 and check the connetivity status.
before downgrading to 3.3-r16 image, can we configure ssid with open autehntication and check client is abel to associate and able do data transfer with ap.
Hi, thanks for your replies. I initially had firmware 3.1-r20 installed when I encountered this problem.
Then I upgraded to 3.4.3-r9, but the problem still remained. Does ist make sense to downgrade to 3.1-r16?
I made a test now with open authentication and everything worked fine. Switching back to WPA2-PSK the problem reappeared.
How can I create a techdump? (I found this option in the "Autopilot"-menues but I do not have the autopilot activated.) Can I create that dump with the classic GUI? Or with the CLI?
Thanks and regards
Conny
What about the log on the Pi itself? try "grep wpa_supplicant /var/log/syslog" and see what it tells you.
I'm assuming this is a USB wifi adapter? (RasPis with onboard WiFi are Broadcom chips) How was the wifi set up - using the GUI or via console editing /etc/wpa_supplicant/wpa_supplicant.conf and /etc/network/interfaces?
I have several Pis with RTL8189 chipset (plus a couple with BCM onboard wifi), the following wpa_supplicant.conf works for them to connect to my E400 APs:
I tried an adaptation of your wpa_supplicant.conf but it didn't work, too.
I do not know if the raspi has a problem with the CCMP cipher, but the logfile in the E400 doesn't show something like that.
Here are my results of the syslog:
Aug 25 16:39:45 raspberrypi wpa_supplicant[378]: Successfully initialized wpa_supplicant
Aug 25 16:39:45 raspberrypi wpa_supplicant[378]: nl80211: Driver does not support authentication/association or connect commands
Aug 25 16:39:55 raspberrypi wpa_supplicant[402]: wlan0: Trying to associate with 00:04:56:ab:9c:xx (SSID='Abbey' freq=2432 MHz)
Aug 25 16:39:55 raspberrypi wpa_supplicant[402]: wlan0: Association request to the driver failed
Aug 25 16:40:00 raspberrypi wpa_supplicant[402]: wlan0: Authentication with 00:04:56:ab:9c:xx timed out.
Aug 25 16:40:00 raspberrypi wpa_supplicant[402]: wlan0: CTRL-EVENT-DISCONNECTED bssid=00:04:56:ab:9c:xx reason=3 locally_generated=1
#then it tries to connect to a second E400 nearby:
Aug 25 16:40:10 raspberrypi wpa_supplicant[402]: wlan0: Trying to associate with 00:04:56:ab:80:yy (SSID=‘Abbey’ freq=2437 MHz)
Aug 25 16:40:10 raspberrypi wpa_supplicant[402]: wlan0: Association request to the driver failed
Aug 25 16:40:15 raspberrypi wpa_supplicant[402]: wlan0: Authentication with 00:04:56:ab:80:yy timed out.
#…and so on…
To compare - the following is a successful connect to a Zyxel accesspoint (using TKIP):
Aug 25 14:21:29 raspberrypi wpa_supplicant[379]: Successfully initialized wpa_supplicant
Aug 25 14:21:30 raspberrypi wpa_supplicant[379]: nl80211: Driver does not support authentication/association or connect commands
Aug 25 14:21:40 raspberrypi wpa_supplicant[446]: wlan0: Trying to associate with 60:31:97:84:c7:zz (SSID=‘GuestHouse’ freq=2412 MHz)
Aug 25 14:21:40 raspberrypi wpa_supplicant[446]: wlan0: Association request to the driver failed
Aug 25 14:21:42 raspberrypi wpa_supplicant[446]: wlan0: Associated with 60:31:97:84:c7:zz
Aug 25 14:21:42 raspberrypi wpa_supplicant[446]: wlan0: WPA: Key negotiation completed with 60:31:97:84:c7:zz [PTK=TKIP GTK=TKIP]
Aug 25 14:21:42 raspberrypi wpa_supplicant[446]: wlan0: CTRL-EVENT-CONNECTED - Connection to 60:31:97:84:c7:zz completed [id=0 id_str=]
Aug 25 16:30:03 raspberrypi wpa_supplicant[446]: wlan0: WPA: Group rekeying completed with 60:31:97:84:c7:zz [GTK=TKIP]
Thanks for the reply. I tested it, but no change. I had tested several configurations before and nothing worked. The problem here is that TKIP is not propagated by the E400, see the AP scan:
To be honest - I do not remember this after such a long time.
Last month I removed the Cambium APs from my network because they did stop working from time to time and exchanged it with Engenius APs. So I cannot retest.
Best regards, Konrad
