I've started to deploy the cnMaestro On-Premises to a client however the majority devices are not showing on Onboard Devices.
The CPEs that doesn't work are configured as a NAT router with PPPoE and Separate management IP and VLAN being used. In our environment there is no route between client addresses (PPPoE) and management addresses.
Devices configured as Bridge works properly.
My guess is that the cnMaestro client on the device is trying to connect through the NAT/PPPoE Wan address/interface instead of the Management IP address/interface.
I can't ping nor complete a traceroute to the cnMaestro IP from the CPE, which I attribute to the same behaviour as with cnMaestro client: the ping and traceroute tools are always using NAT/PPPoE Wan to reach destination.
There are no problems with ping or traceroute from cnMaestro server to those CPEs so routing is working fine on our management networks.
Is there a way to force the cnMaestro client to use the management interface to reach the cnMaestro server?
SMs are running 3.3. However, I tested some running 3.0 and some pre-3.0 before updating to 3.3 to try to fix the problem.
PPPoE servers are running RouterOS 6.38.5. Do you think PPPoE server would be the problem?
I've attached a zip file with two configs, one works with cnMaestro and the other don't. I have replaced some values with "xxxx" just for safety.
If you need any other information, just ask :)
Regards
You are right.
ePMP devices uses PPPoE/WAN interface for interaction with cnMaestro server.
This behaviour was implemented since cnMaestro has been introduced.
We are already have internal issue opened regarding configuration with NAT mode, PPPoE and Management Interface. We are investigating user cases to make interaction between ePMP and cnMaestro most simple and clear for user.
Workaround is to make cnMaestro server reachable from PPPoE/WAN interface. Fix is not going to be delivered in the next release, but we will increase priority for it. Forum is right place to discuss every topic related to ePMP and in general Cambium products. You can contact me directly at fedor.trutsko(at)cambiumnetworks(dot)com in case you have found defects in ePMP firmware. Thank you for your input. It will help us to improve ePMP product.
