Hi!
Thank you all for reaching me out. I am going to contact you next week.
Dmitry
I'm also interested in beta version. U can send me
@someone wrote:I also sent you a private message with our availability for beta tests
Never received the private message?
oi tamben quero testa.
marcos.shunck@bdnet.com.br
Hi all
elevate is compatible in N mode with AC hardware? If no any ETA for the AC version (SXT Lite AC)?
We have 5400 mikrotik CPE half are AC mixed on the APs
Than You Giuseppe
We don't have plans to support Elevate on 11ac SXT devices.
Dmitry
Will this be available for SXT Lite5 devices? I need to know before i choose another upgrade path. I am willing to beta test this on 800+ devices. We have reached capacity and are turning away new customers. Do yo have a rough ETA?
I played with the elevate at Wispapolooza and am ready to see some beta software. On our micropops we are mostly using Sextants and SXT's with a few Lites thrown in. Will the firmware work on all of them or just the Lites? I know this is a somewhat low priority but very important to me as we are piling up the Mikrotik antennas in our storage. I would like to use them. And we are putting off upgrades to areas waiting for the elevate.
Keep up the good work Dmitry.
Hi OrangeTEK,
Right now we are in the process of closed beta. As soon as we finish beta tests we will start public beta.
Initially software will be available for SXT5 Lite units only.
Dmitry
Hi Dmitry,
Of the 800+ CPE's, we probably have 700 Lite5's :) I would a appreciate a very rough ETA for open beta testing even if its not accurate as things are getting desparate here.
Thanks for the quick reply.
Regards
Hi OrangeTEK,
Please check your e-mail.
Dmitry
Hi Dmitry,
can I've software to try Elevate?
Can support QRT5 ?
Dmitry, can you send a firmware to elevate Mikrotik device?
Do you see my mail from profile?
Robert clark
Bolt internet
90 Percent Mikrotik network
please send sxt file i woull like to test and be test subject
have epmp at most of our sites now
netops@boltinternet.com
I'm interested to test Mikrotik Elevate software
We have about 50 sites with Cambium Epmp2000 and 1000 mikrotik cpe (sxt,qrt,lhg)
If possible please send me sxt file, I would like to test
flavio@hellotelwifi.it
thanks in advance
Hi Everyone,
Thanks all of you for your patience. We are fixing the last quirks and will start beta very soon on our beta forum:
http://community.cambiumnetworks.com/t5/ePMP-Beta/bd-p/forums_epmp_beta
Please check that all of you can access it easily.
Dmitry
Have about 1000 sxt
It yells "Access denied" for me...
Access Denied
