To get access to the ePMP beta forum, please visit https://support.cambiumnetworks.com/forum/epmpbeta.
Simon
Simon
OK - after confirming the agreement I am in, thanx...
Hello,
what device is it supposed to support?
We have a network of about 1.5k SXT 5Hnd / Hpnd / HpnDr2 and little lite5.
It's important for planning. No info, bad info, no profit ...
Thx.
tambemĀ temos interesse no teste beta mikrotik, telecom@fibernet.net.br
Hi everyone,
Please check the following topic:
http://community.cambiumnetworks.com/t5/ePMP-Beta/Mikrotik-ePMP-Elevate-Beta/m-p/85024#M921
Dmitry
Hi
when I'm trying log in i see following statement:
Click your browser's Back button to continue.
I have solved described problem.
Tanks anyway.
Is there a list of what Mikrotik devices are supported?
Most networks will have a mix of devices so it would be handy to know if the several different devices are supported.
And does it cover both 'n' and 'ac' devices?
As it has been said:
- only SXT Lite 5 devices,
- only N.
can you send me elevate for mikrotik? i compatible with SXT5 Lite and SXTsq 5 ac? thanks
Hello,
We currently only have Elevate for the following Mikrotik devices:
- only N
You can find the software at the following link:
Can we please get a status update?
When might more devices be supported?Ā
Will it ever support remote programming, so we wouldn't have to visit each house?
communication is bound. The version it sent for sxt lite 3.5.2 is not yet supported by cnmaestro, some shell commands do not work as ping. I did not find the changelog for 3.5.2. After eight months of the first beth, nothing has changed, the support of other units in sight and the back of the Cambium reaction.
some of the units after upgrading from 3.5.2.rc11 to 3.5.2 reset me to default. Did anyone like experience?
Is elevate coming for any more mikrotik models in the near future?
please reply us please !Ā Thank you.
Hi zippo,
I was unable to reproduce the issue on my setup. Just contacted you through emailĀ for a detailed follow up.
Will updateĀ the forum with the findings for others. Thanks.
is there a simple way to elevate SXT Lite5 to cambiunm please provide step by step guide if avaliable.
Any new on an update for mikrotik and the ubiquity antena. i tried the firmware an it give m error 43. pleae somone help me thanks
