Hello all
Anyway to reset the password of PMP 450 beacuse i cannot access two accesspoint?
Thank you
Hello all
Thank you
Thanks Eric. That is the correct way for defaulting devices with a Default Plug connector (i.e. 6-pin connector), which includes PMP 100 and 450.
However, PMP 450i, 450m and 450b use a different method to enter default (or recovery) mode.
This can be found here.
