hello
I need Long Haul Microwave for distance 33 miles and transfer 1 GiB internet
What are the equipment that I should I use?
That's a pretty tall order, but it should be possible. You're most likely going to have to build a licensed link, using 4' dishes, and PTP820C radios. You canĀ use LinkPlanner to build a link based upon your specifications and it will also produce a bill of materials. Alternativly, I'm sure that a Cambium regional technical manager (RTM) could whip one up for you if you give themĀ some basic information.
