Find a location for the ePMP power supply that meets the following requirements:
- The power supply can be mounted on a wall or other flat surface.
- The power supply is kept dry, with no possibility of condensation, flooding or rising damp.
- The power supply can be accessed to view status indicators.
- The power supply can be connected to the ePMP module drop cable and network terminating equipment.
- The power supply can be connected to a mains or dc power supply that meets the requirements defined below
Power supply environmental specifications
Category |
Specification |
Ambient Operating Temperature |
0° C to +40° C |
Humidity |
Power supply electrical specifications
Category |
Specification |
AC Input |
100 to 240 VAC |
Efficiency |
Meets efficiency level ‘V’ |
Over Current Protection |
Zener clamping (38V to 45V) |
Hold up time |
10 ms minimum at maximum load, 120 VAC |
