Hi
Problem configuring a NETWORK with 2 VLANs
The first VLAN is on the network side.
VLAN1 =>
IP 10.0.1.99/24
GW 10.0.1.254
I do have an internet connection
But I have a problem when I enable VLAN2
VLAN2 =>
IP 192.168.20.1/24
GW 10.0.1.254
creation of a DHCP "POOL" on VLAN2
RANGE => 192.168.20.2 to 192.168.20.250
Default route => 192.168.20.1
Network 192.168.20.0/24
In the WLAN SSID "test" I indicate VLAN2 well
I am receiving an IP 192.168.20.2
But you can't connect to the Internet.
From my PC connected to the WIFI with the SSID "test" impossible to go on the internet.
I can do a PING on 192.168.20.1 of VLAN2 but not on 10.0.1.99 of VLAN1
I can't ping 10.0.1.254 of the GW either.
From my PC connected to the wired network, I do have internet access.
But you can't PING on VLAN2 192.168.20.1
But I can do a PING on the VLAN1 10.0.1.99
How is it that routing is not done.
In VLAN2, the "DEFAULT GW" is indicated 10.0.1.254
Regards
