I'm realitvily new to using the link planner, but I've noticed the PTP450's and 450i's do not have GPS sync inside the link planner but in practice obviously they do. Does link planner assume sync or am I missing something here?
The performance of the link (and what LINKPlanner displays) is not impacted by whether sync is enabled or disabled on a PTP 450/450i.
You should be able to add the uGPS as an optional extra if you choose to do TDD SYNC.
regards,
Bruce
Will a PTP450/450i not sync from a CMM thru the power/data connector?
