We have a lot PTP500 LPU can we use them for any of current products ?
You can use them on any 48v equipment: ptp650/670, 450i
Thanks for the response Juan Marriott.
The LPU End Kit for PTP 250/300/500 has part number WB2978. I checked WB2978D, which was manufactured by Motorola, and WB2978H, which was the Cambium branded equivalent. Either of these two versions is suitable for use with PTP 600/650/670/700 and PMP 450i, and will allow Ethernet to negotiate at 1000BASE-T. The LPU itself has part number 2900.
Two things to remember:
- The PTP 500 end kit contains one LPU. You will need two LPUs to protect PTP 600/650/670/700.
- The latest LPU has larger glands, which allow the cable to be pre-terminated with the RJ-45. With the 2900 part, the cable must be passed through the gland before the RJ-45 is fitted.
Mark
Dear All Thanks for your clear reply Best regards Ayman
