Hi All,
Is it possible to use PTP670 PSU and AUX ports to carry two different isolated networks traffic?
Hi All,
I have forwarded this to our support and product team.
Dear Eng Mohamed
Have a good day
We in khalda petroleum company@Egypt already tested it & it worked well over PTP650&PTP 670
You can 100 percent due what you are asking. Reference the user guide for the 670 or contact your local RTM.
I have ticket about this problem: #189702, and conclusion are that from last Firmware this option are not possible ? Last firmware where this is possible are 2-50 (2-60, 2-70 not !!)
It is strange why this option are disabled with new firmware...
It appears that Customer Support have responded correctly.
We have a discussion on the Second Data Service (SDS) in PTP 670 here: PTP 670 Second Data Service
Please look at the link above. It explains how PTP 670 has an embedded Ethernet switch from 670-02-60 onwards, and this provides a more flexible solution than releases up to 670-02-50. If you need the SDS, then the answer is to use the PTP 650 emulation firmware in 670-01-48.
