Is it possible to add a feature that would allow a client wifi to be redirected to a specific URL alfter succesful authentification. Currently, the is provision for a message after succesful login. There should be a similar provision to redirect the client after succesful login.
Hi Equacomm,
Thank you for your feedback. We plan to add this feature to the guest portal, so it's good to know there's a demand for it!
I need this too. I need to redirect when the client connects to the wireless lan. I don’t want any blocking or “click here for access” or terms and conditions are anything that requires interaction. As soon as they are authenticated on the network, I want the redirected, and they must have full network access as soon as they are connected.
