If I telnet into a Cambium radio, is it possible to retrieve information like site name, color code, or model of the radio? I tried a bunch of commands from the help menu but couldn't find these three pieces of information I need. Is this information only available over HTTP and SNMP? I would prefer telnet because it's a lot easier for me to script.
Hi Foobaz,
You can use telnet on ePMP radio however other than that on PMP it is limited to Engineering usage not much can be done there. We don't have Telnet option where you can get information or pull any data if you want to pol the data then you have to use SNMP or use GUI (HTTP).
For your reference I have attached CLI for ePMP radio
Regards,
Gokul
- ePMP CLI Manual v002.pdf (558 KB)
