RayS
(RayS)
1
Check out the range and throughput estimates for different PMP 450 configurations HERE. Use these estimations to plan your network expansions.
RayS
(RayS)
2
The standard path loss calculation is HERE.
RayS
(RayS)
3
The calculation fo r Maximum Power Levels for connectorized units is HERE.
RayS
(RayS)
4
Antenna alignment is a significant factor in network performance. Check out the webinar on Advanced Antenna Alignment HERE.
RayS
(RayS)
5
Receive signal level calculations are HERE.
RayS
(RayS)
6
Fade margin calculations are HERE.
RayS
(RayS)
7
RF Environment analysis methods are HERE.
RayS
(RayS)
8
Tips on avoiding interference are HERE.
RayS
(RayS)
9
Plan ePMP networks using the Capacity Planner tool HERE.
