Defect Fixes (System Release 3.2.1)
Tracking |
Description / Workaround |
13472 |
[ePMP Elevate] Updates to XM hardware Ethernet port interface MAC address assignment |
13220 |
Support for use of shift key to select multiple frequencies in the Scan List |
13165 |
SM does not create static route for separate management interface |
13117 |
ePMP 2000 device configured in SM mode reports incorrect AP frequency and does not register |
12794 |
False radar detection on DFS channel FCC1322 Type1 22 |
12793 |
False radar detection on DFS channel FCC1322 Type1 24 |
Known problems or limitations (System Release 3.2.1)
Tracking |
13530 |
[ePMP Elevate] TFTP recovery may not be used to restore previous non-Cambium device software configuration. This limitation is inherent to the design of the native device software. |
13516 |
[ePMP Elevate] XM hardware – Spectrum Analyzer not supported |
13346 |
[ePMP Elevate] XW hardware – After upgrading a device with ePMP Elevate, downgrading to device native software, and upgrading again to ePMP Elevate, the Device Name and network settings may not be retained |
13343 |
[ePMP Elevate] XW hardware – If an ePMP Elevate module is interrupted during an ePMP software upgrade, TFTP flash recovery of ePMP Elevate software may fail. As a workaround, load the native device software, then upgrade again to ePMP Elevate |
13552 |
[ePMP Elevate] After changing the device management IP address, the browser may not automatically redirect to the new IP address. Workaround: Enter the new management IP address in the browser address bar. |
13630 |
[ePMP Elevate] Upon downgrading from Release 3.2.1 to Release 3.2, the Remote Management parameter may be set to Disabled. Workaround: Re-enable the Remote Management parameter after downgrading from Release 3.2.1 to Release 3.2. |
