I can’t find any detail on these GPS coordinate fields in the rev update docs.
Do the fields do anything? Are they actually useable for sync?
How do they affect the other settings?
There are GPS fieldsin v9.5 as well, and as far as I can tell they do nothing really. It’s just for informational reference.
Frothingdog.ca wrote: There are GPS fieldsin v9.5 as well, and as far as I can tell they do nothing really. It's just for informational reference.
Yep
bysky1000 wrote: I can't find any detail on these GPS coordinate fields in the rev update docs.
They don't affect any settings, all that happens is the device (SM, AP, BH, etc) will be located on the physical map at those co-ordinates -- if you use One Point Wireless Manager.
