I have a SM that keeps loosing connectivity to cnMaestro when i check it i see it's got a 169 ip address, however the dhcp is showing
Server Not Responding. Default IP in use. Still attempting DHCP..., |
It's also acting odd on the session side, i've seen the session drop a few times while i was watching so far its had 50 session reg and rereg in last 5 hours since ap booted... -74 RSL and 16 CINR so nothing shockingly bad that would cause it to disconnect i would think.
The SM is getting it's dhcp enabled via Radius all my other SM's so far seem to be handling this fine but this ones just acting odd. If i reboot the SM it gets an IP it appears, with a 14 day lease so why would it even be trying to talk to dhcp again if it's got a 14 day lease.
On the radius side it also looks very weird,, appears to be hitting the dhcp server every few seconds.
Oct 13 15:42:40 wmserver dhcpd: DHCPDISCOVER from 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:42:40 wmserver dhcpd: DHCPOFFER on 192.168.192.151 to 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:42:49 wmserver dhcpd: DHCPDISCOVER from 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:42:49 wmserver dhcpd: DHCPOFFER on 192.168.192.151 to 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:43:06 wmserver dhcpd: DHCPDISCOVER from 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:43:06 wmserver dhcpd: DHCPOFFER on 192.168.192.151 to 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:43:39 wmserver dhcpd: DHCPDISCOVER from 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:43:39 wmserver dhcpd: DHCPOFFER on 192.168.192.151 to 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:44:44 wmserver dhcpd: DHCPDISCOVER from 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:44:45 wmserver dhcpd: DHCPOFFER on 192.168.192.151 to 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:44:45 wmserver dhcpd: DHCPREQUEST for 192.168.192.151 (192.168.192.253) from 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:44:45 wmserver dhcpd: DHCPACK on 192.168.192.151 to 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:44:49 wmserver dhcpd: DHCPREQUEST for 192.168.192.151 (192.168.192.253) from 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:44:49 wmserver dhcpd: DHCPACK on 192.168.192.151 to 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:44:58 wmserver dhcpd: DHCPREQUEST for 192.168.192.151 (192.168.192.253) from 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:44:58 wmserver dhcpd: DHCPACK on 192.168.192.151 to 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:45:14 wmserver dhcpd: DHCPREQUEST for 192.168.192.151 (192.168.192.253) from 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:45:14 wmserver dhcpd: DHCPACK on 192.168.192.151 to 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:45:47 wmserver dhcpd: DHCPREQUEST for 192.168.192.151 (192.168.192.253) from 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:45:47 wmserver dhcpd: DHCPACK on 192.168.192.151 to 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:46:52 wmserver dhcpd: DHCPREQUEST for 192.168.192.151 (192.168.192.253) from 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:46:52 wmserver dhcpd: DHCPACK on 192.168.192.151 to 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:46:55 wmserver dhcpd: DHCPDISCOVER from 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:46:55 wmserver dhcpd: DHCPOFFER on 192.168.192.151 to 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:46:55 wmserver dhcpd: DHCPREQUEST for 192.168.192.151 (192.168.192.253) from 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:46:55 wmserver dhcpd: DHCPACK on 192.168.192.151 to 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:47:53 wmserver dhcpd: DHCPDISCOVER from 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:47:53 wmserver dhcpd: DHCPOFFER on 192.168.192.151 to 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:47:53 wmserver dhcpd: DHCPREQUEST for 192.168.192.151 (192.168.192.253) from 0a:00:3e:xx:xx:xx via eth0:1
Oct 13 15:47:53 wmserver dhcpd: DHCPACK on 192.168.192.151 to 0a:00:3e:xx:xx:xx via eth0:1
