I have a cnPilot 190 that I want to send it a DHCP address on a VLAN. Attached is my config. Does this look right? I am not grabbing DHCP on the VLAN.
Hi J2sw ,
Config looks ok .
Can you send below info on to my mail id nileshkumar.singh@cambiumnetworks.com.
1. Config file and status page screen capture.
2.Which version you are running.
3. Are you using IPv4 or IPv6 ?
Regards,
Nilesh
Hi J2sw ,
If you are trying to configure IPV6 on WAN port . You will need to enable it first in , Network-->IPv6 advance .
I have got IP for my router WAN port in VALN 10 for both IPv6 and IPv4. See attached screencature from my router .
Regards,
Nilesh
- IPv6Advance.png (33.8 KB)
- Status.PNG (25.9 KB)
- WAN.PNG (58.3 KB)
