I am trying to upgrade a 2.3.4 SM and a 2.4 GPS AP to 2.4.1 and I am getting this error. I have tried to upgrade via the CNS and from the GUI of the SM and AP. Same problem. Any Ideas as to why?
Jan 5 14:45:33 DMV-ePMP02_EAST snmpd[19786]: SW_UPD ERROR: Firmware: Digital signature check: failed
I suggest you to decrease security level in Internet explorer and try. If the still persist then try the below one.
Check this option in Internet explorer property i.e Start>>>Run>>>type inetcpl.cpl>>OK>>> Security >>>Select Local Intranet>>> Custom level>>> Scroll down and check for this option "Don't prompt for client certification selection when only one certificate exist>> Enable/Disable.
If the above option is Disabled then please enable and try. If it already enabled then please disable and try.
