Hey all,
Has anyone tried the 2.4Ghz ePMP SM and RocketDish 24? I'm curious to know the results of this combination in a PtMP scenario.
Thank you!
Hey all,
Thank you!
I've personally never tried this, but I'm sure it will work just fine (we've converted 5GHz RocketDishes for use with ePMP). Alternatively you might be able to get a bit better gain/performance out of the new AirFiber X 2.4GHz Antenna which employs a dual-slant polarity which would match the OEM ePMP 2.4 sector antenna.
we've done it a lot.... awesome results. average 5 to 6 points over the passive reflectors.
