2 suggestion for cnmaestro
1. When client SM is in NAT mode CNMaestro show the local IP as the ip of the SM. I used a management VLAN. I think they should see the Management IP instead the local ip address of the client side...
2. Be able to schedule antenna upgrade. I mostly update client antenna at night and i like to sleep sometime... :P
Thanks for these suggestions.  Defineately seems useful.  They have been noted.
Regarding the second item, "schedule antenna upgrade", I interpret that to mean "schedule subscriber module (SM) upgrade", correct ?
Regards,
Emilio
yes ur correct!
