Hi guy.
We are trying to connect 2 sites with 25km distance. The bandwidth requirement betweent two sites is 2Gb.
I'm quite new with cambium PTP so hope you guy will help with select the product.
Hi guy.
Hi nhuphuc, thanks for your message.
Might you be able to tell me where you are located so I can have a sales person for that region follow up with you?
Best regards,
Mike
Hi MAndersen
Thank you for your response.
Please check inbox.
