So since our network was set up, we have been setting up 4 sector sites using the same ssid/password for all four and have fought over the years with antennas jumping sectors to worse signal. I know now they should have probably been set up as Sector1, Sector2, Sector3, etc. I am working on a solution to get them all to this set up, but have been unsuccessful using JSON in CnMaestro to push configs to add the new SSIDs on the sm’s before i switch the APs. What I dont want to have to do is go into each customer’s SM and add the new SSIDs individually but the more I dig, it seems like that might be the only option. I thought it might be easier if my AP could have 2 SSIDs broadcasting to get them all switched over but thats not an option, We are using 4.6.1 on everything. Also I have probably 20 sites to do, so 80 APs all with customers on them. Any suggestions are appreciated.
Going back to the JSON commands on Maestro, I did have some say they were successful but didn’t change anything in the SM.
Example:
"device_props": {
"prefferedAPTable": {
"prefferedListTableEntrySSID": "sectorE",
"prefferedListTableEntryKEY": "sector123",
"prefferedListTableSecurityMethod": "0"
Using https://jsonlint.com/ validator said it was good and Maestro sent it and came back complete, but didnt have any affect on the SM.
Any better ways of doing this or to accomplish this task?
Or am i stuck adding the SSID in each individual SM then changing the AP SSID after?
Mitch
