3D Printable Ruler - Strip and Check Cat5e (BBDGe) cable
I’ve had to prepare a few drop cables using Cambium WB3176 / WB3175 (Superior Essex BBDGe) cables. As per the PTP manual, it has specific measurements it needs to be stripped and crimped at.
To make life easy, I’ve prepared a ruler. It has two functions:
  • Mark cables so the various layers of insulation can be removed to match the 25mm/42mm measurements as per a PTP radio
  • Check an assembled connector meets the specs
Details here: Cambium Cat5e PTP-670 drop cable stripping / checking ruler by Lawrence Billson | Download free STL model | Printables.com
