4.3.2 vs 3.5.6 Release Recommendation.
4.3.2 release is targeted for pure ePMP3000 networks and in backwards/forwards compatibility mode. However, certain features are not available in 4.3.2 such as QOS/MIR that an operator may need. Due to this, we are recommending continued use of 3.5.6 release for pure legacy networks.
This firmware works with ePMP200?, I use the beta version for compatibility with ePMP3000 but if this is the stable version i going to use them.
UnSargent, yes, 4.3.2 is available for all ePMP devices including ePMP3000 802.11ac wave 2 devices and ePMP1000/2000 802.11n devices, but like Chinmay said, if it's for a purely legacy deployment of 802.11n radios then you're better off using 3.5.6. If you're wanting forward compatibility for your ePMP2000 with F300 devices then you'll need to be on 4.3.2. Makes sense?
I have ePMP200 for CPE and ePMP3000 for AP but I'm using beta firmware because compatibility issues
From support site, You may use ePMP-AC-v4.3.2.img for ePMP3000 and ePMP-NonGPS_Synced-v4.3.2.tar.gz for Force200, Force180 CPEs. This is called 'Backward Compatibility'. You may see this video - https://www.youtube.com/watch?v=3kIQfQsrwFw&t=469s for more information.
Please mae sure to go through following before doing so.
http://community.cambiumnetworks.com/t5/ePMP-3000-2000-and-1000/4-3-2-802-11n-SMs-not-being-able-to-connect-to-AP-issue-and-work/m-p/103375#M16454
Since the're still several issue with 4.4.x release, why remove 3.5.6 from download site ?
Under the archive section for "ePMP 1000 Force 100/110/180/190/200 SM", only 4.4.1 and 4.4.2 are available.
You can find all ePMP software in "Previous ePMP Files" section:
Found it.
