We seem to have had a number of routers become unable to talk on the WAN/Bricked when upgrading to 4.4.2-r2
All was working well until we processed the upgrade in firmware.. Factory reset etc makes no difference..
Hi Jason,
Which device model are you using ?
What is the state of the LEDs after power up ?
What version were you running before ?
How did you upgrade ? Was there any power disruption during upgrade ?
ashutosh
R200p mainly have this issue.
All LEDS off when no lan plugged in.
Lan light does come un when computer plugged in.
Not 100% sure.. a mixture i am guessing.
CNmaestro. No way to tell re power but completed early morning so probably not and with the amount of units ie more than 30 now that have done exactly the same thing i dare so no it was not a power issue.
