Hello, since upgrading 6 AP's to 4.4, I find that when I'm in the GUI, I get the "Connection temporarily lost" message quite often and I never receive that on 3.5.6 or earlier version.
I've verified this is happening on all 4.4 AP's and anything under the 4.x branch is fine, even on the same tower. These AP's are on different towers and backhauls.
Anyone else seeing this when watching the Web GUI for a few minutes?
Hi all,
I hope the issue doesn't affect any major functional for you.
We have already fixed it and fix will be available in the next FW version.
@Fedor wrote: We have already fixed it and fix will be available in the next FW version.
Cool - while you are fixing things in the web gui... I'd LOVE to see the "Inactivity Logout (*) Disable" type of switch available on the initial login screen. Or maybe even just the wording of a "Keep me logged in" type of button on the main loging screen
So basiclly, when I'm logging in: the main screen should ask me Username, Password, AND 'keep me logged in' or 'Inactivity Timeout Disable' right there on the main login screen, please. :)
I hate having to drill down to the configuation/settings/inactivity logout disable on every AP I log into - dozens of times per day.
Yep. They either don’t agree, and don’t care to try. Or worse yet, they don’t understand… and they spend time and resources working on ab issue, without actually solving what we needed.
