we have quite a few 450m radios with 450i and 450b SM-s mixed. We have tested recently and found that the max MTU that can pass the link is 1682 (and not 1700 as it should be)
We are using 16.0.1 mainly on the radios, and using the SMs in bridge mode.
Has anyone else experienced this?
The maximum Ethernet frame size supported by PMP 450m/450i/450b series is 1700 Bytes. You are right. The max MTU supported is 1682 bytes(1700 - 18 bytes of Ethernet header).
