Just like the title says: these units won't respond to pings from powercode when configured as NAT. When set as a bridge, everything is flawless. All the units in the field are running 13.2.1.
The SM is not accessible via IP, but I can reach it from the AP. Is there a filter setting that I need to disable when using NAT?
Excellent. That was exactly what I needed. Many thanks.
I noticed that enabling NAT seems to disable the 0a:00 interface, and instead uses 2a:00, and 3a:00. The IP assigned to the 3a interface is used for remote access, and the address on 2a looks like the WAN facing one.
