The POE injector that comes with the 4500 is 3,6,4,5 + and 1,2,7,8 -. Can it be powered by a UI switch that does 4 pair 54V power but uses 1,2,4,5+ and 3,6,7,8 -?
I am specifically looking to see if I can power it from the UI Edgepoint S-16 switch. It has (4) 54V passive 4-pair ports and then (12) 24V passive (2pin) or POE+ ports.
Yes, the radio is polarity agnostic so you can power it with either pinout. The 4500 will also work fine with 2 pair poe as long as you can provide 32 watts max - though I’ve never seen that high of a draw from one.
The mapping you list is reversed on every pair, not just a different 4-pair layout. Some PoE inputs are rectified and tolerate reverse polarity, but don’t assume the 4500 does unless Cambium specifies it. Check the 4500’s input voltage range and polarity requirements. If it is polarity-sensitive, the S16’s 54V passive ports would need a crossover adapter, or use the supplied injector. The 24V ports are not suitable. Also confirm the S16 54V ports are truly always-on passive 4-pair, not negotiation-dependent.
