450i 900 MHz backhaul radio configs
I am new the 450i product.  Since this is a backhaul radio, can I use the master to generate internal sync?  I have the sync pulse set -
sync pulse status -- Generating Sync
Sync Pulse Source -- Self generate
Yes, you can! Keep in mind that by having it generate it's own sync, that you will not be able to sync it with other PTP450's collocated. Having a radio generate it's own sync is a good solution when you want to save money and not have to buy a uGPS, or sync injector, and you only have one or maybe just a few radios collocated at the same site that are all using different channels.
Thanks!  there is only one on site and we don't plan for any others.
