Is there any info on how to use the frame calculator to make 900 MHz FSK and OFDM coexist? Not necessarily same tower, but same area, other operators. Like let's say my AP is pointing right at one of theirs, 9 miles away, LOS.
The only way I get the numbers to look similar is to specify 2.5 ms framing for OFDM. But I thought 900 FSK used a 5 ms frame, double what 2.4 and 5 GHz used.
