I have a Medusa 450b running the cbrs band. The signal strength is about -40 (too hot?) And the snr is 43 dB. It stays this way for about 24 hours, then something happens and snr spikes and shows yellow/red. The connection is basically unusable until I reboot the radio.
What would cause this? Attached is the alignment screen.
The following screenshot is a second radio that does the same thing that I just happened to catch and take a picture of.
