Hello Friends,
I want soultion for 45Kms Point to Point Link, LOS is clear. Currently i am using Mikrotik Netmetal with 30dBi antenna, but not getting proper throughput.
Please suggest something better.
Hello Friends,
Have you downloaded and installed LINKPlanner?
LINKPlanner is a free tool that will help you make this kind of decision.
Get it here!
https://support.cambiumnetworks.com/files/linkplanner/
Dave
Suggest you model the PTP 450i using LINKPlanner as suggested by David. A second option may be the ePMP Force 200.
