4600 Manual
Hello,
Where can I find the manual for the ePMP 4600?
Additionally, how do I reset the 4625 back to defaults? I used a paper clip in the reset hole for varying amounts of time, and still no access into the device.
How do I set the 4600AP back to defaults?
Hello @FVI_Support,
unfortunately, the manual for 4600 is still under development.
You can use a manual for ePMP3000 as the general features work the same way. ePMP3k and Force300 User Guide
To reset a radio to defaults there are two methods. You can use Reset button or use power-cycle procedure. Please, check this guide.
