Hi all was wondering if this could work for a 4600c…
Thanks!
It’s not really an ideal antenna for the 4600c as the band cut off is 6GHz. Past 6GHz the antenna’s performance may behave unpredictably and the farther out of spec you operate the antenna, the worse the performance will typically be. I would not use this antenna unless you have nothing else OR if you only intend to run your 4600c in the 5.7-5.9GHz range.
Appreciate the feedback! Do you have any 6ghz backhauls, if so what antenna are you using?
Thank you for the Link. Is the Ultra Dish 29 a 2ft antenna?
Read the spec sheet and find out.
