Noticed while checking my backhaul links that the slave unit is showing no AFC data on one of our primary backhaul links. The master side is fine. The link is up and working but the display is saying AFC DEVICE STATUS is disabled. Running 5.9 on the radio. Is this a bug? I assume a reboot would fix it but will have to wait to the wee hours to do so. I did download the tech support file if needed.
Is the GPS on that radio working?
It looks like the radio didn’t get geolocation form the GPS.
Thanks.
AWAX6GRAFFSL>config show | afc
cambiumAfcProxy2Port 3128
cambiumAfcProxyEnable 0
cambiumAfcProxyPort 3128
cambiumAfcStaMode 1
AWAX6GRAFFSL>
Hi @Riverrat,
it looks ok. Could you PM me a techsupport file. Will try look deeper.
