4600c PTP ST disassociation
Hi all, I have 2 4600c in ptp 160mhz, 5.9.1 firmware and the SM has randomly disassociated itself from the AP. Has anyone had this issue? Has upgrading to latest firmware solved this? Any issues arise when trying to upgrade? Link is in full production and I cant afford an unnecessary outage.. we have had very little grace with outages from customers especially with things that are out of my control.
my issue concerning SM’s disconnecting was fixed in 5.11, can’t say we had the same issue though.
I take it your situation was a 6ghz ptmp situation?
Hi @DigitalMan2020 ,
What was the disconnect reason?
Did it come back by itself? Or did you do anything else to recover?
It came back by itself when it happened, log show “ST initiated disconnect”. I updated the link to 5.11.0RC63 and will monitor/wait if it happens again.
STA initiated disconnected means it was due to some SM settings change. Like networking or radio paramters.
No setting changes were made when this happened, it has happened twice within this Month, both at random times.
Hi Andrii, the STA initiated disconnect happened again this morning, no settings changed on SM so really confused why this is happening
Hi @DigitalMan2020,
drop me the techsupport file please!
will do, thank you very much.
Files sent, thank you again.
