Hi;
Which one of these Tycon Power DC to DC converter PoE inserter solutions will work to power the following ePMP 1000 5GHz SMs? Looking for a solution / exact model to be specific, which will work from a -48V DC input battery source to power and support any of these ePMP 1000 5GHz SM models. That is, an ePMP 1000 5GHz SM (integrated) and an ePMP 1000 Force 110 SM.
I know that there is a "48 V DC Input Voltage PoE Options" post by Cambium. That is, "http://community.cambiumnetworks.com/t5/ePMP-Installation/48-V-DC-Input-Voltage-PoE-Options/m-p/40437#M22". But the links posted in this go nowhere and when they do show, it's in an Asian language (not English). The post was really helpful in that it gave me a starting point. Kudos to Cambium for having the information and posting it for the ePMP community.
However, I came across these Tycon Power solutions, which appear to be much more readily available.
- http://www.tyconpower.com/products/files/TP-DCDC-HP_POE%20Inserter-Converter_Spec_Sheet.pdf
- TP-DCDC-4824-HP +/-36-72VDC IN 24VDC OUT, 30W DC to DC Converter with POE Inserter
I also figured that if we were to have an application where we need to power the ePMP 1000 5GHz AP or an ePMP 1000 GPS version which supports an 802.23af PoE, we can possibly use this model:-
- TP-DCDC-4848D-HP +/-36-72VDC IN 56VDC OUT, 35W DC to DC Converter with 802.3at POE Inserter
If any one can confirm which Tycon Power solution will work or help with a 48VDC DC-to-DC input solution for the ePMP 1000 series.
Thanks.
