5.10.0 and QOS
Just upgraded all our 4500L to 5.10.0 and noticed today the QOS uplink is now jacked. Seeing the same thing across all APs. For example, have QOS package set at 100/30 yet when I run a speed test, it is reporting 100 down and 10 up. Same on all SM’s across multiple APs, upload speed does not match what I set in the APs QOS setting any longer. Going to play with the setting after house and see if I can reenter them with a slight change.
I just tested and saw the same thing.
QoS enabled with default profile on AP (~976Mbps UL/DL) and I get around 50% of what I should get on the UL. DL does not change.
40mhz 75/25 5ms
Here it is with QoS disabled on AP.
