Can I get the RC too?
@aka I have multiple issues since updating to 5.11, im experiencing High Ping for SMs, Poor throughput performance and at peak hours im only at 48-50% frame time usage, 40 mhz channel, I have some SMs being dropped and picked back up by the AP. Link scores are high, my SM link score 200 down and 27 up and my speed tests are 90 down and 20 up.
is it possible to have the 5.11 release?
Hi @DigitalMan2020 ,
could you reset statistics, execute WLT 2-3 times and drop me techsupport files from AP and 2 SMs?
Hi Andrii, yes I can. Did you get the AP tech file I PM’d you?
@aka I sent requested files to you via PM. I tried both mu-mimo options and then beamforming and then beamforming off, no change, I still had SMs being dropped and then added every 5-8 minutes. I have went back to 5.10.4 and problem disappeared.
Hi all,
5.11.0-RC54 Beta has been released.
Thanks.
Is anyone still having issues with 5.11.0-RC52? I had to go back to 5.10 because on 5.11 52 I had 4-6 SMs being disassociated and reassociated every 5-8 minutes.
Hi! I would love to try the 5.11 beta too! I’m trying to solve a low performance issue with a 4500L on 5.10 and a friend told me to try the beta ![]()
you should apply to Beta thread
Hi @Niccolo_Pietrobon, welcome to the Cambium Community ![]()
The 5.11 beta is now available to members of the ePMP Open Beta program. You can find details of how to join here:
