What is the max range for the 20Mbps 5.2 backhaul with a reflector?
Is it the same unit for use with and without reflector? i.e. You just dial up different power settings? If yes, what is the max power you can set without a reflector?
I am a bit confused because the product specs show only reflector versions when I thought both were available.
Many thanks
I don’t think we are allowed to use 5.2 with reflectors. ?
You can use the dish on the 5.2’s typical LOS range they state is 5 miles but you never know with these things. sometimes you can exceed the limits if the conditions are good. Just remember that the farther you go the less bandwidth you will have.
